Help !!! Needs 730 starter bracket!!!
dave from MN
07-02-2005 13:10:37
Am desperatly looking for a starter mounting bracket for a 730 Deisel. Neighbors done broke in to. God neighbor in his 60's. Really needs to get this tractor up and running. We are in central MN but could drive or arrange shipping. Any used dealers that may be out there that you know might have one would be appreciated as well.
Carl NY
07-02-2005 17:25:55
 Re: Help !!! Needs 730 starter bracket!!! in reply to dave from MN, 07-02-2005 13:10:37
Call me on my cell phone. I can help him out. Call 315-945-7138.
Jerry Byrd
07-02-2005 16:29:09
Give Triple G Service a try ,they should have one.1-888-720-0830.
dave from MN
07-02-2005 13:11:49
Sorry . It is electric start not pony. Hey, He would be open to changing it back to pony if we found a decent rig.
buickanddeere
07-02-2005 19:27:28
 Re: Help !!! Needs 730 starter bracket!!! in reply to dave from MN, 07-02-2005 13:11:49
What happened to the cranking engine? Is this a 12 or 24V coversion? Does this tractor have to start in the winter? Has the owner added up the present and future cost of every part to properly convert to electric?
dave from MN
07-02-2005 20:09:17
 Re: Help !!! Needs 730 starter bracket!!! in reply to buickanddeere, 07-02-2005 19:27:28
Is 12 volt and already changed Electric start. Any 730d in my opinion is worth what ever it takes to keep in running order, and I'm an IH person.
buickanddeere
07-02-2005 20:36:24
 Re: Help !!! Needs 730 starter bracket!!! in reply to dave from MN, 07-02-2005 20:09:17
Make certain every little part and piece of the cranking engine set is saved together is a dry safe place and well labelled. Odds are that tractor should have a permanent tow chain fastened from the drawbar up to near the front frame weights. It takes a lot of planning, $$$ and work to get a 12V system to make as much HP as a cranking engine in cold weather. The Diesel engine has to be in a better state of tune when electric started than when using a cranking engine to get decent starting. Keep that de-compression lever operational.
720Deere
07-03-2005 14:44:47
 Re: Help !!! Needs 730 starter bracket!!! in reply to buickanddeere, 07-02-2005 20:36:24
It's funny how much power it takes to really crank those diesels. A guy that I work with farmed with a 730 electric start and he says that even when the batteries didn't have enough guts to crank the diesel under compression, they would still motor the tractor around in 3rd gear with the compression released. His solution when the batteries were weak and he needed to start the tractor was to motor the tractor with the starter and get to a good hill where he could drift it. He swears it worked like a charm, but I've never taken a notion to try it with dad's 720. I think he would kick my arse just like I was 10 again.
Don't even try to drift start on of those with worn out tire on grass! I had pony problems a few years ago and had to drift or pull my 720. We only had trailer enough for one tractor at a time back then so mine got left behind one night at a pull. It rained that night and when we went to get my tractor in the morning, I had a dickens of time getting enough traction to start it in any gear. Of course that was extreme mud more or less, but I've had similar experiences in grass when it is dry.
