High Reverse
Louie,2
07-02-2005 08:09:57
I bought a 1936 B John Deere, and I understand that if it is in high range when you shift to reverse, that it should auto shift back to low range. Mine doesn't do that. I have taken the trans. cover off and can't see anything that is broken or missing."I really don't know what I'm looking for". Can some of you fellows tell me what causes the high-low range to shift back to low range? Thanks in advance.
Mike M
07-03-2005 20:38:24
 Re: High Reverse in reply to Louie,2, 07-02-2005 08:09:57
There were some implements that required you to drive around backwards. A cotton picker comes to mind for sure.You should of had a pin in the shifting fork that would shove over on the high low fork when trying to go to reverse.
havvey
07-02-2005 14:08:37
there was a type of pin/if removed/disabled you had a high range reverse my g has that if i were you i would leave it alone it can be handy and won't hurt it at all if you notice from the olivers to present tractors they have multipe reverse options it is the similar idea to locking out gears 5/6 on oliver and deere with steel wheels. those old timers were pretty smart compared to most of us!
RalphinWI
07-02-2005 10:25:27
Some farmers disabled that feature on the unstyled tractors and used high reverse as a transport speed. Yes backwards up the road, no trailing impliment of course. When looking a 46 A, it was fairly obvious, but those details escape me now. You may have to compare your transmission to the appropriate parts book.
Island A
07-02-2005 12:39:54
 Re: High Reverse in reply to RalphinWI, 07-02-2005 10:25:27
Why in the world would a farmer want to drive his tractor up the road backwards???
Dave
RalphinWI
07-02-2005 15:11:24
 Re: High Reverse in reply to Island A, 07-02-2005 12:39:54
It supposedly was a good bit faster than 4th or H-2 the fastest forward speed. During the 40's farmers still hadn't worn out those 2 bangers all of which started with 4 speeds designed to accomodate steel wheels. Farmers were expanding by renting land which might have been a couple of miles away. During that time our tractor was used to cut hay early in the morning, drop the #5 mower, put the cultivator on and cultivate until the hay raked by the last team of horses on the farm was dry, drop the cultivator and use the tractor to pull wagons and hay loader during the afternoon. With a type A personality, if your concern was transporting the tractor from one site to another, removing a part from the transmission, was a lot cheaper than buying a Heisler conversion or a new tractor.
buickanddeere
07-03-2005 18:02:07
 Re: High Reverse in reply to RalphinWI, 07-02-2005 15:11:24
Tried the 70D in high reverse today w hile reading speed with the GPS. Wearing 18.4x30 tires she made 5-1/4 mph in "R"acing gear.
old
07-02-2005 08:24:49
Your right it should shift it to low, I looked in my 1935 owners manual and that isn't covered in it so all I can do is guess. I think the thing your looking for is on the cover, not in the tranny. By the way that manual I looked at is the real deal not a reprint and its not often I will even pull it out of the zip lock bag I keep it in.
Louie Walker
07-02-2005 16:49:05
 Re: High Reverse in reply to old, 07-02-2005 08:24:49
I'm sure somebody has switch the forks around Put the left fork on the right,and the right fork on the left and it will work Louie
