3010 stops without pushing brake pedal down?????
Patrick Bryant
07-01-2005 20:13:16
3010 will slowly stop without pushing brake pedal down. Tractor has not been towed. I've been told brakes could be stacking. I have changed transmission filter and found no metal filings of any kind in the filter. Planning on putting some Lucas additive in transmission fluid to see if this helps in case top shaft is binding some. What should I check next? Will I do more or any damage if I use the tractor? The right brake pedal hasn't worked in years but have not had this problem until now. Let me know what you think. Thanks
ET
07-03-2005 03:38:08
 Re: 3010 stops without pushing brake pedal down??? in reply to Patrick Bryant, 07-01-2005 20:13:16
The brake pedal valve is leaking on one side and putting the brake on.
msb
07-01-2005 21:16:41
I would be very hesitant about adding anything to the transmission oil in the hopes of a cure.I think you will be wasting your money.Chances are you have a brake valve partially open .Take the brake valve off and have it rebuilt,especially in light of the fact it hasn't worked in years.Do as the other poster advised except place the shift lever in the tow position.That will completely disengage the top shaft.
matthies
07-01-2005 20:24:26
Jack the rearend up and see if the wheels both turn with the same effort(by hand) while trans. is in neutral. This will narrow it down to a side at least. You said nothing in the filter, how about the screen. later chris
