J.D. 830 Diesel clutch
R.K.
07-01-2005 18:06:47
Have a 830 diesel 2 cylinder. Inner bearing froze up on crankshaft, cannot get the clutch belt pulley off. Clutches and plates are removed. Throw out bearing fork also removed. The center nut is also off,and have the splined pressure plate off to. Any help would be apppreciated. Thanks Ralph Bearing has been froze so long it wore a deep grove in belt pulley
greenmech
07-02-2005 21:04:43
 Re: J.D. 830 Diesel clutch in reply to R.K., 07-01-2005 18:06:47
Ralph, sounds like you need to take off the clutch driver, the part that the nut holds on. It will need to be pushed off with the two holes with bolts or nuts against the backing plate. Ron Mn. Good luck ,let us know how it works.
