48 A powr trol
J Blk
07-01-2005 16:35:41
Does the PTO need to be running for the powr trol to use a remote cylinder.
Mike M
07-01-2005 19:08:19
 Re: 48 A powr trol in reply to J Blk, 07-01-2005 16:35:41
There was an optional hyd. pump that fit between the gov. housing and the mag. or dist. and was plumbed into the power- trol makeing it live hyd. so you didn't need to run the pto. You may have one,if not and you want one they turn up often on ebay.
John T
07-01-2005 16:56:51
Yep, the PTO has to be engaged for hydraulics to work cuz its turning runs the hydraulic pump. Also to convert from rock shaft operation to remote hydraulics, you need to change those power trol plugs or else have one of the adjustable ones with a nut under a removeable cap cuz you have to divert the oil flow from the rock shaft cylinder to the remote couplers outlets.
John T
