'42 JD A stalls when warmed up, but starts again
nathan_dc2
07-01-2005 08:19:39
Working on a 1942 John Deere Series "A" tractor. The problem is after the tractor has run for a bit and is warming up it will stall, it takes a few turns of the flywheel but it will start again and if you keep the throttle at wide open you can keep it going to get it back home. Has new plugs and condenser (no points yet wrong parts ordered in), new fuel. What is happening?
1945 A
07-01-2005 13:25:10
 Re: '42 JD A stalls when warmed up, but starts aga in reply to nathan_dc2, 07-01-2005 08:19:39
I think your problem is definitely fuel related.
I"d start by making sure the carburetor is getting good fuel flow---just take the line loose at the carburetor, and make sure you"re getting a good stream of fuel to the carb. If not, then check your fuel filter to make sure it"s not clogged.
Your float could be stuck, trash in the needle valve, not letting gas get through.
If you"ll search the archives, there are lots of threads regarding fuel system problems and remedies.
Good Luck!
P.S. A carburetor kit won"t give you specific instructions as to how to clean these carburetors--- my kit consisted of a couple of gaskets and a new needle valve in a plastic bag. If you run into trouble, you can call Robert"s Carburetor---they can help you out....
old
07-01-2005 10:59:33
Coil maybe going bad, or its not getting enough gas.
nathan_dc2
07-01-2005 12:39:06
 Re: '42 JD A stalls when warmed up, but starts aga in reply to old, 07-01-2005 10:59:33
is it possible that I am experiencing vapour lock. I am probably going to remove the carb this weekend and give it a good cleaning, I don"t have the service manual so I don"t think I will dismantle it.
old
07-01-2005 13:00:45
 Re: '42 JD A stalls when warmed up, but starts aga in reply to nathan_dc2, 07-01-2005 12:39:06
If you buy a kit for that carb the instructions will be in the kit. If its a vopar lock which is unlikely if you remove the gas cap it would/should fix that. You may also have the vent in the cap clogged.
