Brake shoe linings, who rebuilds?
Joe Howard
07-01-2005 06:33:10
I am metal to metal on my 50B brake shoes, owing in large part to me "riding" the brakes to hear the engine chug. No admonitions please, I know every one of you have done it at one time or another. Replacement costs for same from the local JD dealer approach $300 considering taxes and shipping. Does anyone put new lining on the old shoes? Can't be rocket science, surely someone would do it. Joe Howard
Skyhawk Greg
07-01-2005 12:34:28
 Re: Brake shoe linings, who rebuilds? in reply to Joe Howard, 07-01-2005 06:33:10
Hi Joe, Your JD dealer sells a set of brake linings complete with rivets specifically for your tractor. I think they were a bit less expensive ($30-$40) in the set vs individually. E-mail me at [email protected] if you would like the JD part number. I don't have it here.
Drilling the old rivets out is very easy. Putting the new rivets in, is where it becomes a little more tricky. Seems as though, when using a transfer punch, that the rivets are always either just a bit too loose, or they are just a bit too tight, and they crack the linings. I prefer to use a gradual, controlled force when installing the rivets. You can get the rivets nice and tight, without cracking the linings this way. If you are interested, again, e-mail me, and I will send pictures of a rivet tool I made out of a leaf spring splitter, the home made rivet tool that the local JD dealer uses, and a picture of the actual tool that is supposed to be used. They all work equally well, and the priciple is the same. You should be able to come up with something yourself. If not, I live near Medina, Ohio and would be glad to do it for you if you live close enough to bring them. Greg
720Deere
07-01-2005 10:32:29
Like Ben said, it's a pretty simple job if you have a little patience. I drill the ends of the old rivets and then punch them out. I used a thin nut that fit inside the lining rivet recess to rest the rivet head/shoe on and hand punched them on top of my anvil. I use a tapered punch to get a flute started on the rivet and then finish it off with a flat punch. No that it matters because you won't be able to see them on the tractor, but mine looked just as good as the ones I've seen done on a press.
As stated previously, start in the middle of the shoe and work out both ways.
Ben.So.Tex.
07-01-2005 08:34:58
I just did one of my 720 yesterday.I ground the back of the old rivet smooth,punched it out, Then put the new liner back on starting in the center and working my way back. Have a buddy hold the shoe while you set the rivits, I put a 3/8 bolt in a vise and put the head of the rivit on it and then used a tranfer punch to brade the rivet worked good for me. Took about and hour start to finish. Good Luck. Ben... Liners for both brakes..62.00 @ John Dealer
Dan in Ohio
07-01-2005 07:43:43
Joe, Your right its not rocket science and you don't need any special tool. What you will need is a set(actually 2) transfer punches. You can get them from Tip tools or JC whitneys cheaper. Just buy the linings and rivets from JD, put one punch in your vise, use the other to flair(mushroom) the end. Thats what Clooney advises and it works great.
Mitchp
07-01-2005 06:39:08
Hey joe, i had mine done awhile back, it takes a special tool to get the rivets back in, i took mine to a local clutch and brake shop, he had a machine that did it. I would look around town for a brake shop and see if they would do it. You can still get the linings from deere and they come with the rivets.
