4010 Fuel Strainer problem...
Reutelhuber
06-30-2005 18:52:33
Hello gurus, I have a 4010 LP tractor and it has been a work horse for me. Recently to start the tractor I have had to spin the coil head on top of the propane strainer until I heard the solenoid click and I knew liquid was flowing. A couple of days ago I could not get the solenoid to click but I was geting 12 V to it. So I replaced the coil on top of the solenoid ($69.00) thinking that was the problem but alas I have the same issue. Any suggestions on where to look next? I would like to take the entire solenoid off but I just filled the propane tank and I would loose all that propane if I unscrew the fuel lines since my liquid shut off valve is stripped. TIA
matthies
06-30-2005 20:12:54
 Re: 4010 Fuel Strainer problem... in reply to Reutelhuber, 06-30-2005 18:52:33
If you are getting 12 volts to it where did you ground your testlight/multimeter to. Sounds like you have a ground problem, run the ground wire from the coil to a good ground and see what happens. good luck
Reutelhuber
06-30-2005 20:43:24
 Re: 4010 Fuel Strainer problem... in reply to matthies, 06-30-2005 20:12:54
I grounded the VOM to the bracket supporting the generator to ensure I was getting 12 volts to the strainer coil. The coil is grounded to the screw on top of the metal casing for the coil ususally. I'll try and run the ground off the coil to the ground on the battery tomorrow and see what happens. Thanks for the speedy reply!
