2010 pto clutch oil
davids
06-30-2005 18:20:44
While changing the roll pin in the pto lever, I noticed the pto clutch area is seprated from the trans. oil, is the pto clutch supposed to be dry?If not, what weight oil is used? Thanks,davids
Mike M
07-01-2005 05:04:52
 Re: 2010 pto clutch oil in reply to davids, 06-30-2005 18:20:44
I changed one of those roll pins once for someone.Alot of work just to get to one pesky little roll pin ! I used a sprial wrapped roll pin so it was stronger.Also heed the warning decal that should be on there about not shifting the lever when the engine is stopped ! I think this is how they broke theirs. And yes they are to be dry.
billde
06-30-2005 20:02:34
Yes is is supposed to be dry. there are seals to keep fluid out from the pto case to the rear and the trans/diff in front. If any of those seals are leaking it will cause problems down the road.
davids
06-30-2005 20:55:23
 Re: 2010 pto clutch oil in reply to billde, 06-30-2005 20:02:34
is the box where the pto shafts are at suppose to have oil in them?Thanks, davids
billde
07-01-2005 04:45:28
 Re: 2010 pto clutch oil in reply to davids, 06-30-2005 20:55:23
Yes that box uses hyd oil. Make sure you keep it filled to the correct level, lots of gears, bearings, and seals in there, also a set of shift forks.
Bob
06-30-2005 21:45:00
Yes.
