720D Standard power steering problem
Tsmith1499
06-30-2005 18:16:11
My 720 will turn right okay, but is hard as a rock to go back. I have done exactly what the IT book(and our local JD expert) said to do in adjusting the power steering. Engine running, loosen 4 bolts on steering rod housing and tap lightly forward or backwards until it turns easily both ways. Yea right! Tried it tonite, with no success. It will either go left , or right easily, but not back the other way. HELP!! What am I doing wrong or what can I do to correct this. BTW it is full of JD PS fluid. Before you ask. Thanks, Tom
TSmith1499
07-01-2005 21:56:00
 Re: 720D Standard power steering problem in reply to Tsmith1499, 06-30-2005 18:16:11
I have only tried the first method I described as was told to me by an old JD mechanic. I guess I wil have to get deeper into her. I definately want it to work. But let me get this straight. Even if I think I moved the valve, but nothing visibly happens, it could be adjusted? I guess I just have to get out there and play with it some more. Didn't see anything in the IT book about how to center the valve. I guess I need to look again. Thanks, Tom
buckeye al
07-01-2005 14:35:36
Mike M is right. These can be real touchy. Not much movement can make a lot of difference. I usually punch out the roll pin & slide the steering shaft back when making the adjustment you're speaking of. Have you adjusted the worm bearing clearances & set the actuating sleeve adjustments? All for these adjustments work together each impacting the other.
Mike M
06-30-2005 18:20:45
Sometimes it only takes a fraction of a fraction of movement. Jack the front end up and center the valve so that when you start it up it stays straight and doesn't drift to one side.
