185 PTO
T
06-30-2005 08:28:46
I have an older 185 which was running fine. I put gas in and started off again to mow. I flipped the switch up for the mower and nothing happened. I saw smoke and smelled something hot. I can turn the pulley by hand it makes a sharp noise. It won't turn when I flip the switch. Help!!!
Joe Padavano
06-30-2005 11:52:08
 Re: 185 PTO in reply to T, 06-30-2005 08:28:46
"...I can turn the pulley by hand it makes a sharp noise. It won't turn when I flip the switch...."
Not sure what you mean by a "sharp noise", but the way the electric PTO is supposed to work is that the pulley will freewheel on the shaft when the switch is off and will lock to the shaft when the switch is on. If you turn the switch on (with the engine stopped) and you can't turn the pulley, then the PTO is probably working fine. As another test, with the engine stopped and the key on, you should hear a click when you turn the PTO switch on.
As for the source of your smell, it sounds like the mower drive belt is slipping someplace. Check the tensioner lever on the mower deck and ensure the belt is tight. If it is, release tension on the mower drive belt and see if you can turn the mower blades by hand. If there's drag there, you may have a bad spindle or idler bearing on the mower deck.
CodyN
07-01-2005 11:10:27
 Re: 185 PTO in reply to Joe Padavano, 06-30-2005 11:52:08
I also have a 185 and had a similar experience. When I flipped the PTO switch, it would click but the mower deck wouldn"t engage. I had to replace the PTO clutch.
