2040 hydraulic problems
Wayne6362
06-30-2005 06:27:20
We have a John Deere 2040 with a front loader that repeatedly keeps blowing the seal at the top of the steering column. Would anyone know what the possible root cause could be? Thanks!
nater
07-04-2005 08:39:16
 Re: 2040 hydraulic problems in reply to Wayne6362, 06-30-2005 06:27:20
Some of those tractor had a pressure reducing valve on the right hand side of the tractor so the steering did not get the full pressure of the system. This is true for the open center system
WTW
06-30-2005 08:21:59
Wayne, Could be one of two things causing this. If the seal has been replaced and it did not blow seal out until the steering wheel was turned the problem is o-rings leaking on steering cylinder rods within the steering valve assembly. If the seal pops as quick as you start the tractor it could be o-rings around the steering valves or a steering valve that is leaking if it is a open center system. If repairing piston rod o-rings you just as well reseal the complete steering unit. If going after just the steering valves, they can be resealed and or replaced without removing the steering valve assembly. Give me some more quirks and information on what it is doing. Is the tractor an open or closed circuit hydraulic system? DW
Wayne6362
06-30-2005 11:56:12
 Re: 2040 hydraulic problems in reply to WTW, 06-30-2005 08:21:59
Thanks DW!
I"ll have to get the book out to determine if it is an open or closed loop system and also if the steering valve has an open center.
The seal does pop just by starting the tractor and letting it run a few minutes and not turning the wheel. We did take the hydraulic systems high pressure/low pressure valve apart and check it thinking that maybe it was sticking in high pressure and causing the weakest point to blow?
I"ve worked on plenty of cars but know very little about tractors and any help is greatly appreciated!
Thanks
Wayne
WTW
06-30-2005 12:35:58
 Re: 2040 hydraulic problems in reply to Wayne6362, 06-30-2005 11:56:12
Wayne, If your hydraulic pump ahead of the radiator is small slender looking (gear type pump) it is a open center system. If it is a large round pump with plugs around the outside diameter of it, (radial piston pump) it is a open center system. Being seal pops out just starting the tractor it sounds like your problem is the o-rings (6) around the steering valve bodies. These o-rings are about two inches in diameter with a very small cross section and do fail and can cause the problem you are having. To replace the o-rings the steering wheel will have to be removed then the jam nut loosened and the threaded inner nut that retains the seal that is failing will come off next. Once off set steering wheel back on and turn the steering wheel, steering shaft and valve assembly will be pushed out of housing and give you access to steering housing bore where the six o-rings are located in there individual grooves. It will take a long pick and a flashlight to replace the o-rings. After installing o-rings oil up the valve assembly and reinstall in reverse order. If the two valve assemblies have shim washer material hanging out beyond the outside diameter of them the will need to be replaced and readjusted or the shim stack hanging out where it does not belong will damage the new o-rings you just replaced when reinstalling valve assembly. In event valve shimming needs to be done it will require tools to do so and you will need to see your JD dealer for that. Some dealers do not chose to adjust these valves as it is time consuming if they never done one and they would rather just sell you a new valve that will be priced at about $250.00 each. So if they can't shim them tell them you know someone who can. If shimming of valve is not necessary replacing the o-rings in housing would take me about 30 to 45 minutes to do so. Good Luck, DW
Tx Jim
07-01-2005 04:15:24
 mistake in reply to WTW, 06-30-2005 12:35:58
WTW,I think you mis-typed open-center after radial pump.Tx Jim
WTW
07-01-2005 07:13:13
 Re: mistake in reply to Tx Jim, 07-01-2005 04:15:24
You are right I need to read my stuff closer. Good Catch! Thank You, DW
