John deere 2130 hydraulics not working
kenith
06-29-2005 20:53:57
After using the tractor for a while the hydraulic stop working. You can kill the tractor wait a few minutes and restart they will work for a few mintues then out again. I have change the filter and cleaned the one inside the rear end. What could possible be the problem
buickanddeere
06-29-2005 22:00:49
 Re: John deere 2130 hydraulics not working in reply to kenith, 06-29-2005 20:53:57
Did you clean the screen? What did you find stuck in the filter? Is the oil level low? Does the oil get hot? Are you using a loader, three point hitch, hydraulic remotes? Or does this affect the brakes, pto, high/low shift and steering?
kenith
07-01-2005 06:26:46
 Re: John deere 2130 hydraulics not working in reply to buickanddeere, 06-29-2005 22:00:49
I cleaned the screen and changed the filter found nothing in the filter and the screen was not bad. oil level is fine I haven't checked to see how hot it is getting. I am using the three point hitch and pto and it affect brakes, pto, high/low shift and steering? I changed the filter and fuild twice one week because i didn't know about the screen until I had changed the fuild.
buickanddeere
07-01-2005 19:03:21
 Re: John deere 2130 hydraulics not working in reply to kenith, 07-01-2005 06:26:46
You are going to have to monitor the trans low presure pump output pressure and the main pump pressure. In order to find which is failing or failing 1st. 1-800-522-7448 for the service,parts and operators manuals. You can't trace the system through or trouble shoot it without a guide and some numbers.
kenith
07-02-2005 13:55:15
 Re: John deere 2130 hydraulics not working in reply to buickanddeere, 07-01-2005 19:03:21
Thanks for the information.
