4020 D serial #
Brian Lill
06-29-2005 10:59:11
I just bought a 4020 D powershift and it was a 1963 and the serial number is 7609 and the stock number is temp00007. could someone give me an idea of what i bought
4020dt
06-29-2005 17:59:54
 Re: 4020 D serial # in reply to Brian Lill, 06-29-2005 10:59:11
4020's came out in the fall of 1963 but they are listed as 1964's , I have never seen a 4020 serial## listed as a 1963 . First 4020 was ###65,000 , 1964's ended around 91,000 . The 64's , 65-91,000 diesels that is , had the big injectors like the 4010 had , differential lock was not available on the '64 models but Powershift was available from the first 4020 and on . I have a 1964 4020D Powershift ser## 84,XXX somewhere around there , also have a 3020D Powershift 1964 .
John Jenkins
06-29-2005 15:03:52
Your 4020�s serial number should look like this:
SNT213R127655R
That particular serial number is from my 4020, a �66 model. Did you check for any clues in the �serial numbers� section of this site? Good luck.
Jason Z in MO
06-29-2005 14:05:54
Did you get the "stock #" off the serial number tag located on the rear of the tractor below the seat?
The 4020 had a serial number with a string of letters and numbers. Much like a automobile VIN number. It can be decoded to provide the engine type, transmission type and tractor catagory.
Do you have that number?
TylerARK
06-29-2005 13:13:34
Well, kinda hard to figure since the 4020 started with serial # 65,000 in 1964. no idea what a temp000 # is...
I was gonna say that is a 4010 serial number but there werent any 4010 powershifts built.
You never know what you will find.
We just got a 1964 4020 in, it has LP stamped in the serial # tag but someone put the front half of a 4010 diesel on it. It is 4020 from the clutch housing back and 4010 forward...
Tyler
Mike M
06-29-2005 12:52:51
Funny I thought power shift didn't come out until 1965 ????
Bob
06-30-2005 08:56:50
 Re: 4020 D serial # in reply to Mike M, 06-29-2005 12:52:51
I've never thought my 1964 PS was "FUNNY"!
msb
06-29-2005 19:05:06
Nope,1964.The 64 model had a longer clutch disconnect lever than the 65s and up.You can spot em a mile away.
