49 A killing battery
manitoba farmer
06-29-2005 07:02:00
I have a 49 A that has been changed over to 12
volts. Every thing works fine except it kills the battery overnight.It was like this when we got it so I am not sure how the wiring shopuld be. thanks JIm
ChuckW
06-29-2005 11:48:38
 Re: 49 A killing battery in reply to manitoba farmer, 06-29-2005 07:02:00
If this tractor has generator, you are probably leaking down through the regulator. If the regulator stick big time, it can cause a wiring shortage or fire.
Maark
06-29-2005 10:52:58
If it has an alt., it could have a bad diode internally. it also needs a diode inline to keep it from draining the battery.
John T
06-29-2005 10:05:34
Farmer, From what you say, I take it as a slow discharge NOT any fast discharge where the Generator gets real hot as can happen if the Voltage Regulators Cutout Relay were sticking in which case the ammeter swings to heavy discharge anytime you turn her off correct????? ?
If its just a slow trickle discharge, do as Frank noted and check loads one at a time like lighting circuits n switches and see which one has a resistive short path to ground, and thats whats discharging the battery.
If its NOT any short circuit, maybe the battery has a bad cell??? Is there electrolyte above all the plates and no cells have a gray or milky color??? Had it load tested lately???
John T
F-I-T
06-29-2005 08:08:08
third party image
Hi Jim:
I've had several '48/49 A's over the years, and they all came from the factory as 12 volts. Anyway, I have a little circuit that uses a lamp that will probably help you pin point the drain. I think it's pretty self-explanatory. Basically, if power is draining out of the battery, the lamp hooked in series will glow. You unhook one wire at a time (in your case it is probably a stuck cut-out contact in the voltage regulator) until the lamp goes out. My own version of this includes an old door buzzer from a car so I can hear the short as well as see it. Once the lamp goes out, double check by hooking up all the other wires to their respective terminals until ou are left with the one that causes the drain. You will be able to touch it to it's terminal and cause the lamp to glow. That's the wire that has the short.
Frank
