JD 50 will not fire
DJC
02-26-2004 15:38:49
We have a 53 JD50 that will not fire. When the ignition is on there is power to the coil, plus and minus, as well as the distributor where the lead wire comes in. The secondary cable has been tested and there does not seem to be any problems there but when we turn it over there is no spark at the plugs. What else can we trouble shoot to try pin point the problem.
Clooney (points prob.)
02-27-2004 03:40:49
 Re: JD 50 will not fire in reply to DJC, 02-26-2004 15:38:49
DJC, you say..
Quote: "When the ignition is on there is power to the coil, plus and minus, as well as the distributor where the lead wire comes in"_____ _____ _____ _____
~That says you have power to the coil.. You need to check the distributor side of the coil while cranking the engine.. The distributor side of the coil needs to go from around 12 volt to around 0 volts as the points open & close.. [11-12 volts points open,, & 0-1 volts points closed].. If it doesn�t, you have oxidized points, incorrectly set points, or an open in a wire in the distributor. If your condenser is shorted you would always have 0-1 volts & never higher..
~If all you have is a test light it would be either lit or not lit instead of the above 0 & 12 volts..
~The usual cause of a problem like yours is corroded or oxidized points, so try cleaning or replacing the points first. I presume you have a Delco [round body] distributor] & if so the points gap is .022� on the high part of the distributor cam.
~OK, if you get to the point where the distributor side terminal of the coil is going from 11-12 to 0-1 then back to 11-12 volts etc. while cranking & you still aren�t getting a spark,, try pulling the coil wire out of the distributor & holding to within 1/8�-3/16� of the engine block while cranking.. If you don�t get a spark then you probably have a bad coil.. If you do get a spark there but not at the spark plugs suspect a defective distributor cap or rotor, or bad plug wires..
~If you do get a spark in the coil wire test above then try new spark plugs before anything else.
__Any questions or follow up help don�t be afraid to post back,, or E-Mail me directly for further help__
[email protected]
DJC
02-27-2004 07:20:08
 Re: Re: JD 50 will not fire in reply to Clooney (points prob.), 02-27-2004 03:40:49
Thank you, will keep you informed as to the progress.
Clooney (you're welcome)
02-27-2004 09:39:31
 Re: Re: Re: JD 50 will not fire in reply to DJC, 02-27-2004 07:20:08
DJC, I sure hope it's something easy to find.. It sure sounds like it is a points problems though like I posted above.. Just make sure those points are clean & gapped properly [oxidized points are a big problem on a 2-cylinder Deere that sits unused for any length of time]�
~Please do keep us informed on your progress.. If you need anything else just post back or E-Mail..
[email protected]
John T (Troubleshooting)
02-26-2004 20:50:04
Good Evening DJ, I will cut n paste my entire coil ignition troubleshooting procedure after I get some feedback from you, or I can e mail it,,,,, , but first specifically address posible causes of the symptom you described in your post. CHECK THE POINTS FIRST FOR GOOD CLOSURE AND NOT BURNED. That may simply be the cause of no spark. (see below for reasons)
1) With the ignition on, there should ALWAYS be voltage present on the coils high (not to distributor) side, BUT NOT on its low (to distributor) side when the points are closed, which is MOST OF THE TIME, since they only open when a piston is at Top Dead Center and then only briefly.
2) If you place a test lamp or voltmeter on the coils low side or on the distributors terminal (same electrical point), turn the ignition on and crank the tractor over, it should flash ON and OFF as the points open and close. Pistons dont usually stop at TDC, especially if up on compression, which is why the points are usually closed in which case the coils low side should be dead grouned (via closed points) showing NO VOLTAGE there.
The points MUST CLOSE and provide a ground return path so the coil can conduct current. If the points dont close (or burned or corroded) or theres an open wire to the distributor or the distributor isnt grounded, the coil cant ever conduct current and she will NEVER SPARK.
3) IF A TEST LAMP ON THE COILS LOW SIDE OR THE DISTRIBUTORS TERMINAL NEVER GOES OFF, THE PROBLEMS COULD BE:
a) The points arent closing or are burned or corroded. CHECK THEM FIRST
b) The distributor isnt grounded.
c) The wire from the coils low side to the points is open. THINGS TO LOOK FOR
--Inspect the points to see if they are closing and not burned or corroded.
-- Make sure the wire from the coils low side to the distributor is good.
-- Make sure the distributor is grounded to the tractors frame.
Shes NEVER gonna fire until the points close and are not burned and wired so the coil can conduct current and drop the voltage on the coils low side (distributor terminal) to zero when points are closed. If as you say the coil shows voltae on BOTH sides or always on distrubutor terminal (same point electrically) shes never gonna fire until you get the low side to ground via the closed points via the base of a properly grounded distributor. i.e. a test lamp on coils low side or distributoir terminal has to flash ON and OFF (as engine rotated) before she will fire
FINAL: Check to see if the distributor is well grounded,,,,,points closing and not burned,,,,, ,good wire from coil to distributor. BY PASS TESTS: With the ignition on and voltage on coils high (from ignition) side, take a wire to the coils low (to distributor) side or the distributors terminal, and jump it momentarily to frame ground and each time you attach then unattach it, the coil should fire. If so but NOT via the distributor and points, points are burned or not closing or an open wire or distributor isnt grounded.
If that isnt the problem, I will paste or e mail you an entire coil ignition troubleshooting procedure. No need to guide you through all that just yet if its just bad points or a wirign or a distributor problem.
CONDENSOR. If a condensor is totally OPEN or not conencted or not even there, you would still get a spark if all else was correct. If a condensor was dead shorted bad, she wouldnt spark HOWEVER, if that were so, the voltage on the coils low side would be zerooooo oo (if all else okay) and since you say its hot on BOTH sides of the coil, I dont think you have a condensor problem causign no spark for now based on your post (it could still be bad however)
Post back or e mail your findings to [email protected] with any questions or call me at 812-824-4608 and I will, try my best to help you. Theres much more that may be the problem, but check the points and wiring and see if you can get the voltage on the coils low side to go OFFFFF FFF and flash On and OFF as engine rotated and then once thats achieved if she still dotn fire, I will advise you further. Hopefully other opinions on other possible problems will follow, but check those points and wirign and distributor ground first.
Good Luck, God Bless, Let me know
John T Nordhoff
DJC
02-27-2004 07:21:29
 Re: Re: JD 50 will not fire in reply to John T (Troubleshooting), 02-26-2004 20:50:04
Thank you,I will let you know how it goes.
John T
02-27-2004 07:32:27
 Re: Re: Re: JD 50 will not fire in reply to DJC, 02-27-2004 07:21:29
Youre most welcome, check them darn points for full closure and lack of burning or carbon or pits etc as I posted above and post any new questions or if you want more detailed troubleshootign tips posted or e mailed. John T
Chris THE REAL CHRIS
02-26-2004 17:26:46
Hey if it ran before and not now it just might be the points are a bit corroded. If your checking fire at plugs the could be bad. THanks
Chris
02-26-2004 17:23:02
You probably have a bad condenser in the dist. Try a new one or one that you know is good, I'll bet that is your problem.
Good luck.
