Tom, first of all, the points and condensor will NOT have to be changed at all. They are more current switching rated devices than volatge type devices. Next, YES you can probalby buy points and condensor and the 12 volt battery and ballast resistor at NAPA, but all they will ask is the tractor etc NOT whether or not you have a 6 or 12 volt regarding the points. Im not sure if they have elec ignitions however, see below If you want to make it a 12 volt from a 6 volt system, what you will need and ask for to answer your question, is: 1) 12 volt battery. (unless youre changing to an alternator) I would wire it POSITIVE ground also, same as an original 6 volt system. 2) A voltage dropping ballast resistor to reduce the 12 battery volts down to 6, what the coil was intended to handle, similar to the NAPA ECH 1CR13 or equiivalent. It simply wires in series with the circuit from the ignition switches IGN output down to the coils high (NOT to distributor) side, so it drops 6 leaving 6 to the series coil. IF YOU WANT TO USE AN EXISTING 6 VOLT COIL THAT IS. Otherwise, you can just buy a new full 12 volt rated internally ballasted coil and use it with no need for any external voltage dropping ballast as before. 3) Its possible to make a good 6 volt generator charge at 12 volts by replacing the old 6 volt regulator with a 12 volt Voltage Regulator (Ive done it), but to make it actually correct, you will now need a 12 volt generator and 12 volt volatge regulator (same JD Delco type unit, just a 12 volt) or go to a 12 volt alternator if you prefer. (Many would require you to change over to neg ground however, post back if you go that way) 4) Starter will work, ammeter will work, but you will need to change any light bulbs from 6 to 12 volts. If you need any wiring diagrams or diagrams for the circuits I described or help in convertign to an alternator, post back or e mail me at [email protected] or call me at 812-824-4608 and I will try my best to help you. I would probably just add the ballast to your existign 6 volt coil,,,,,change light bulbs,,,,,get a 12 volt gen and Voltage Regulator (same JD Delco type, just 12 volts),,,,, ,,get a 12 volt battery wired POS ground, polarize the new gen and youre off to the races. SIMPLE AS THAT YES you can buy elec switching units to replace the points and condensor, they are in the 80 to 120 $ price range, and are available in 6 or 12 volts, pos or neg ground I believe, not sure, from like Genessee or Pertronix etc and others. Thats a whole other post, ask me if yoiu need any help if you go that route. Good luck, God Bless, let me know if you have any questions or need help or wirign diagrams etc. [email protected] John T Nordhoff
