4010 LP misses badly
Phil C
06-28-2005 12:47:22
I have a 4010 LP that I've been trying to get running right for the last year. Replaced everything electrical including wires and distributor. Pulled the head, new gasket, compression OK and even ran Propane gas direct bypassing carb. This engine still misses badly which gets worse as it warms up. Any suggestions would be appreciated.
txgrn
06-29-2005 15:26:38
 Re: 4010 LP misses badly in reply to Phil C, 06-28-2005 12:47:22
Had a rebuild on a 4020 LP. Missed a sentence in the manual, after the TDC things that had to be done, that said "now advance the timing to 25 BTDC". Once I discovered that and did it it made a profound improvement on the performance.
Seems you located it to spark, now which cylinder and why. Good place to start is dist. Pull wire out of top of dist (for each cyl, one at a time) and move in and out watching spark jump as you get closer and farther. Pay attention to any variance in spark intensity or engine noises as you go around the dist. If you find a variance then pursue.
Mark
