50 exhaust pipe
Trump
06-28-2005 10:48:28
Need to replace the exhaust pipe on my 50. Were it bolts to the manifold looks simple. But up on top looks like it could be a pain. Will the nose cone and hood need to come off or can I work around this. It seems to be loose were the muffler bolts down to it. Maybe take the nose cone off so I can raise up the hood a few inches. Exhaust pipe looks like it could be the original,pitted and holes are starting to show up. Its got to come off to repair or replace. Since I have to take it off might as well put on a new one.
Mike M
06-28-2005 11:48:03
 Re: 50 exhaust pipe in reply to Trump, 06-28-2005 10:48:28
By the time the model 50 was built they finally built them so you could change the muffler WITHOUT removing the hood.If the cast piece that the muffler bolts to (an adapter that attaches it to the rad.) is loose it may be broken off as this is common and many have been welded.
Trump
06-28-2005 11:59:28
 Re: 50 exhaust pipe in reply to Mike M, 06-28-2005 11:48:03
I need to replace the exhaust pipe not the muffler. How does the exhaust pipe attach to the part that the muffler bolts to?
Ben.So.Tex.
06-28-2005 12:25:54
 Re: 50 exhaust pipe in reply to Trump, 06-28-2005 11:59:28
It just sticks in there and floats free, only two bolts at the manifold that's it..No more it's done
Trump
06-28-2005 13:47:59
 Re: 50 exhaust pipe in reply to Ben.So.Tex., 06-28-2005 12:25:54
Sounds like an easy fix. Thanks Ben
