 SH Greg: I have applied true clear coat as used to top coat in a Base/Clear Coat automotive system on carburetors, and it works pretty well. The piece has to be very clean, since you don't get the chance to use a self-etching primer that will contain Phosphoric Acid. Here's an older photo of a Marvel-Schebler TSX-112 which came on my Case VAC. I cleaned the cast iron and steel parts in my electrolysis bath, then brushed them with a new stainless steel toothbrush sized wire brush. Then I applied phosphoric acid to clean it some more and to give the surface more tooth. Then I cleaned it in the bath again just to be sure. I wiped it down with Prepsol (or generic wax and grease remover, generally containing Xylene) and applied about three coats of clear in light coats. Be sure to tape over any threads or ports that you do not wish to have coated as this finish builds quickly. Now this clear product is an automotive style product, so you will have to read and follow label directions for safety and durability. If you try to use any type of coating that is not catalyzed (two-part) you will be disappointed. The carburetor is one item that has a constant weepage of fuel and vapors 24/7, so an enamel will ultimately lift at the edges and the separation will grow from there. I would not recommend trying any spraycan product or synthetic enamel. You just cannot get it tough enough no matter what hardener product you use. Frank
