I think there can be a great disservice done to prospective tractor paint jobs if one only focuses on the simplicity and economy of using synthetic enamel for a finish. If synthetic enamel were the panacea of painting, then I think the big Three might still be using it in their factories today, but since they are not, there has to be some reasons. I'm a believer in if you can spend the same or even less money and apply a good quality acrylic enamel product, you will have a more durable finish that will resist fading like no synthetic enamel ever has. I priced acrylic enamels for my VAC Case project, and there are many (example is LIMCO and low-line PPG) that can be had for less money than the equivalent JD synthol product. As far as the hardener being $35 a pop, I paid $20 for a 16 oz can of each of the "Wet-Look" brands product for synthetic and acrylic, so no difference in cost, and since you only add one ounce to each 8 ounces of paint, the cost to add the appropriate hardener is more than balanced by the increased durability, fade resistance, and shine that you will achieve. You also tend to have much more choices in reducer temperatures with a AE than you will with synthetic. "Synthol" paint is so outdated that no auto builder has used it for over 35 years and as such, it is not well supported with additional reducer grades. As far as Ford having problems with early '90's clear coats, GM had problems of their own keeping sliver or light blue on their cars even in the synthetic days, and in the 80's and 90's it peeled off whether it was synthetic, acrylic lacquer, acrylic enamel, or even base/clear. There has been a lot of improvment made in the urethane clearcoat of 2005 versus 1995. Now, I understand that not everyone wants to apply that level of finish, but I saw the thread a while back saying that people should take greater pride in performing work that they were going to eventually call "restorations". A quality paint applied to quality preparation is a big step in making that a reality. I understand that acrylic enamel might be considered a bit tougher to deal with given the safety precautions that must be observed with it's use with cyanoacrylate hardeners, but the same goes for a synthetic enamel that is applied with a catalyst. Any spray application has a list of do's and don't's and the majority revolve around buying and using a proper fresh air breathing system. I just think that the same money can buy a better paint system. Sorry for being long-winded, but I think acrylic enamel gets pushed to the side too quickly in favor of synthol, which is really no safer to apply, no cheaper to apply, and does not last as long in the same environment. Seems as though his painter already appreciates the difference and that is why he was asking for MS codes. Frank
