1020 gas water pump problem
Chris Hadden
06-27-2005 20:24:58
My water pump was screetching badly so I took it out and had the John Deere dealer rebuild it. Runs nice and quite but leaks like crazy around the fan shaft. It was making noise but never leaked. Was wondering if this is the fault of the guy that rebuilt it or whether the housing is possibly no good. Any thoughts before I get nasty with the dealer.
Mike M
06-28-2005 06:08:02
 Re: 1020 gas water pump problem in reply to Chris Hadden, 06-27-2005 20:24:58
Unless that housing is cracked (however it happened)it should be rebuildable as the seal wears against the impeller both of which should be replaced. The seal is a light press fit in the housing so it doesn't wear it out.Something may of just not seated right or broke or they got a bad seal.Take it back and have them redo it. No fun to pull off twice but it should be faster the 2nd time around (Don't ask me how I know ! )
Roy Suomi
06-27-2005 20:37:42
absolutely take it back if you're sure installation was correct. There is a bleed hole at the bottom of shaft boss behind pulley. I've rebuilt many without a problem. I have however, broken a couple of housings while pressing the bearing out.
Chris Hadden
06-29-2005 02:04:07
 Re: 1020 gas water pump problem in reply to Roy Suomi, 06-27-2005 20:37:42
Thanks for the response guys. I will take it back. One other thing I was curious about. I did not have to pull the radiator to get the pump out but it was difficult working in that tight space. Do you think it is quicker in the long run to pull the radiator?
