7720 injection pump
hogman_2002
06-27-2005 19:16:57
I bought a 7720 combine that has been sitting for 4 or 5 years. It's gonna be used for parts. So for the last few days I've been trying to get it running and get it home(it's about 35 miles away from my house). I drained all the old diesel and put new filters on it and fresh diesel in it. When I tried to bleed the system, I could only get diesel to 4 of the 6 injector lines. After about 30 minutes I still couldn't get diesel to number 1 and number 4 injectors. So I tightened the lines at the injectors and decided to call it a day. After I put up all my stuff I decided to give it one last try. I had my brother turn the motor over and to our suprise it started. It sputtered at first but started to pick up rpms. I told him to cut it off and when he pulled the fuel cut off switch it kept running. I cut the key off and told him to cut the valve off at the diesel tank. After he did this, the motor kept running for about 20-30 seconds. I kept pulling on the cut off switch but the motor kept running until it ran out of diesel. While it was running it seemed to be running fairly smooth and not missing. But it was emitting alot of black smoke. I'm worried about why I couldn't get it to shut off. Is this an easy fix or will I have to pull the injection pump? It's just a parts combine so I may try to drag it home if I can't get it started. But I would rather drive it home.
HTR
06-28-2005 04:40:36
 Re: 7720 injection pump in reply to hogman_2002, 06-27-2005 19:16:57
You have one or more pumping plungers stuck. The six pumping plungers rotate in their bore to control the fuel delivery. When you move the throttle lever, all you are doing is putting more or less tension on the Governor spring inside the pump. With a plunger stuck, the control rod for the racks is not moving. Sometimes, if they are not stuck very tight, you can take the side cover off the side of the pump, and free the rack control, with a screw driver and patients. Don't force them very hard, as it is easy to break the little balls off the sleeve that rotates the plungers. The rack control must be absolutely free, or you risk a run away situation.
57ringo
10-07-2005 19:48:57
 Re: 7720 injection pump in reply to HTR, 06-28-2005 04:40:36
Do you have a picture of the pump with the cover off or an exploded view so I can see what you're talking about? I have a 7720 doing the same thing.
msb
06-27-2005 20:18:04
Sounds like the kill cable needs adjusting.Its on the backside of the injection pump next to the block.Not very easy to get to.Pretty sure it takes a 10 mm (nut driver)wrench.Personally, I would start it up and drive it home and not worry about the kill button until I got it home.The black smoke should clear up on running it for a short while unless the turbo isn't doing its job.I would be more concerned about that.Everything else you said sounds normal for that machine.
hogman_2002
06-27-2005 21:00:15
 Re: 7720 injection pump in reply to msb, 06-27-2005 20:18:04
Msb, the kill cable is adjusted correctly. That and the throttle linkage was one of the first things I checked before trying to start it. Both of them work like they are supposed to. Is there anything inside the injection pump that could have broke or that might be stuck?
msb
06-27-2005 21:21:31
 Re: 7720 injection pump in reply to hogman_2002, 06-27-2005 21:00:15
Been a loooonnnggg time and my service school book is up at the farm 10 miles away.Guess I should bring all my service school books home.That kill lever is supposed to pull the rack all the way back to the stop position,but I can't remember how it works at the moment.Hey, can't I have a senior moment?lol,bob----Does the kill lever operate like it isn't even hooked up to anything? On the turbo,if the smoke doesn't clear up, you could remove the either line fitting and see if the manifold has pressure on it ,I guess.
