9-Bolt Hubs
Big Country
06-27-2005 18:51:10
What is the secret on getting the hubs on the axle. I got the 6-bolt hubs off wasn"t much trouble. But I can"t get the hub on the axle with out taking a hammer to it. The axle and the hubs both 12 spinle. You have to hit the hub pretty hard to get it to move. I have cleaned the axle & hub. Thank"s for any help.
JDBert
06-28-2005 06:23:01
 Re: 9-Bolt Hubs in reply to Big Country, 06-27-2005 18:51:10
Do you have the hub clamps off? I usually slide the hub clamps on the axle with the bolts sticking in them then line the hub up. Those ears on the 9 bolt hubs seem to "spring" together more then the cast hubs and usually start on the axle hard. I would assume that you've got them painted and thats why you dont want to use the hammer. If everthing is clean and slighly lubed a rubber hammer should work well to move them. Dont use to much lube! I've done that and had them "walk" back out on me before.
Mike M
06-28-2005 06:15:35
You say you cleaned the axle and hub. Were they rusted ? If so you may need to sandblast them to get it all out.You didn't built them up with alot of paint did you ? If everything is Clean and paint and rust free and you still need to tap them on you may just have really good fitting parts not erroded away from time. Put them where you want them and rest in the fact that once tight they will stay where you put them.
msb
06-27-2005 20:23:52
When I used hub type duals,I took a bolt that fit the bolt hole,cut the head of the bolt off and ground the bolt down to a point.Threaded the bolt into the hub and used it as a guide to install the wheel without fighting it.Two bolts would probably work even better.
Pat Browning
06-27-2005 19:48:52
Apply Kroil or PB Blaster & allow some time for it to work.
See if you can find June 2004 Issue of Green Magazine -- See Dan Brotzman's method of dealing with these.
If by chance you strike out, send me your e-mail and I will ship his article to you that way.
[email protected]
Pat
