3020 PowerShift PTO engagement
DreamingGreen I
06-27-2005 18:23:10
I'm grateful to an earlier posting that helped me learn that the linkage to the PTO engagement/brake valve on top of the bell housing was loose.
It's tight now, but I have two issues. One is placement of the coil spring. I put it where I thought it should be, but the PTO will not stay engaged. Can anyone describe where the spring supposed to go really?
Second, as I engage the hand lever, there is some gear grinding as engagement begins, but it ceases after I push on past that point. I thought perhaps the grinding would go away after I removed the slop from the lnkage, but it's still there. I would appreciate any advice. Thanks. BTW, my tractor is a 1064 3020 Diesel PowerShift. And the tractor is even more fun now that I've discovered this discussion board.
msb
06-27-2005 21:07:08
 Re: 3020 PowerShift PTO engagement in reply to DreamingGreen IN, 06-27-2005 18:23:10
Can't help you with the noise without hearing it.Could be a normal noise for that transmission's PTO. The spring attaches to the valve control lever just behind where the operating rod attaches to the valve operating lever.(down inside)The other end of the spring attaches to the part of the cowling that juts out on the left side of the opening.It hooks below a small spring coming down from the top.Clear as mud?
DreamingGreen IN
07-09-2005 05:40:25
 Re: 3020 PowerShift PTO engagement in reply to msb, 06-27-2005 21:07:08
msb - All is well now, definitely better than before. Thanks much for the help. LG
DreamingGreen IN
06-28-2005 09:25:44
" ... below a small spring coming down from the top". Hmmm. I think I'm missing a spring.
Your description was cyrstal clear. (This could have been a frustrating attempt at communication. My compliments!)
About the noise, it sounds - and feels - like engaging an unsynchronized gear turning fairly rapidly. But not as fast, for example, as when we miss a gear in a Syncro-Range trans.
In any case, thanks for the reply.
Larry
