3020 powershift woes
Dennis Webber
06-27-2005 14:57:48
Having a difficult time figuring out why tractor fails to move when putting it in gear. I started out adjusting the clutch valve, I used a manual. Still no results, tractor does move after a certain length of time. When tractor is moving, I engaged the pto and the tractor stops. Disengage the pto, and the tractor moves after another amount of time. I cleaned the transmission screen, it was pretty well clogged with a lint material. After cleaning the screen, tractor still has the same symptoms. I split the tractor behind the engine, took the transmission pump to a mechanic, we found nothing of significance to indicate problems there.I just pulled the clutch valve it is clean, very little wear, see no problem with it. Where should I proceed from this point. The torsion damper has a spring missing,from the clutch disc. The big spring was laying in bottom of housing,the little spring that goes inside of the big one is nowhere to be found. I suppose it was ground into bits. Any ideas or comments are certainly appreciated. deererunner
buickanddeere
06-27-2005 15:34:47
 Re: 3020 powershift woes in reply to Dennis Webber, 06-27-2005 14:57:48
A pressure and flow test of the trans charge pump is required to verify it's operation. And to locate any leaks in the low pressure plumbing/valves. You will have to put it all back together to trouble shoot then maybe take her apart again. What flow rate from the front high pressure pump could be taken before system pressure dropped below 1750 psi? What is the line apply pressure to the trans planetary clutch packs?
msb
06-27-2005 21:27:46
 Re: 3020 powershift woes in reply to buickanddeere, 06-27-2005 15:34:47
Just a WAG.Remove the front of the clutch pack and inspect the gasket under the face plate.I have seen gaskets fail there.Sounds like you are losing transmission pump pressure when you engage the PTO.
