730D clutch
JDJACK
06-27-2005 14:47:39
How do I removed clutch pulley? I think that the clutch dogs are sticky. Tractor is jumpy then clutch in engaged slowly.
720Deere
06-27-2005 16:44:40
 Re: 730D clutch in reply to JDJACK, 06-27-2005 14:47:39
You really should get a service manual from Deere or an I&T manual. That being said, it's not that tough of a job. First you remove the clutch adjusting or pressure plate that is held on by the 4 adjusting nuts. Then you remove the friction disk and the bolt in the center of the crank. The clutch driver comes out next. This requires 2 ea - 1/2" bolts to be threaded in through the holes in the driver. This will push the clutch driver off the crank.
After the clutch driver is out, the linings and floating disks need to be removed. You will need to unhook the clutch linkage where the shaft goes down into the reduction housing. At this point the dust shield behind the pulley will need to be unbolted. Now you should be able to pull the pulley straight out. Most times the right rear wheel will need to be moved out for the pulley to clear the crank. She's heavy so be careful!
I am not sure that the dogs would cause a jumpy clutch. Many times that is caused by oil or grease on the friction material of one or several of the disks. One of our 720s had that problem and it is smooth as glass with new friction material in place. If you need clutch parts try aftermarket as they are much cheaper than Deere and have performed flawlessly in 2 of our tractors. If you need a source, hollar back and I'll post some info.
720Deere
06-29-2005 15:05:14
 Re: 730D clutch in reply to 720Deere, 06-27-2005 16:44:40
I'm sorry, I stated that there were 4 adjusting nuts and there are only 3. Sorry for the confusion.
