JD 2020 runs hot
Ragsbo
06-27-2005 09:38:27
I have a JD 2020 that just keeps overheating. We had the radiator boiled out and cleaned, it seemed to help a little. But this year, it won't run anytime, without overheating.
Any suggestions??
Ragsbo
06-28-2005 14:29:26
 Re: JD 2020 runs hot in reply to Ragsbo, 06-27-2005 09:38:27
I removed the thermastat and flushed the system out. It seems to be running cooler but I haven't had time to check it for more than 30 minutes (flat tire). I plan on leaving the thermastat out during hot weather and putting it in when it cools off. So far everything else checks out. I am running a 6 foot bush hog doing brush/weed/pasture clipping.
buickanddeere
06-29-2005 07:01:05
 Re: JD 2020 runs hot in reply to Ragsbo, 06-28-2005 14:29:26
Put a new stat in while you are at it or you never will get around to it. Stats and gaskets are cheap. Engines worn out and fuel wasted from being run cold are expensive.
buickanddeere
06-27-2005 15:46:46
Collapsed lower rad hose, pump impellar spinning loose on it's shaft, leaking rad cap, out of calibration thermostat, worn belt pulleys and worn glazed belts? Retarded engine timing from a stuck advance mechanism? Leaner than normal air/fuel mixture?
Mike M
06-27-2005 10:22:10
How's your thermostat ? Check for improper timing,blowed head gasket,even bad impeller on water pump,clogged up block ?
