Hydraulic pump droven off fanshaft?
ebbsspeed
06-27-2005 08:14:18
Thinking about how to add live hydraulic pump to my Model B, and was wondering about the feasability of running a power steering pump off of the fanshaft to be used as a hydraulic pump. I don't know how durable the bevel gears that drive the fan shaft are, and would like opinions as to whether this would be a bad idea. Thanks!
J. Schwiebert
06-27-2005 19:50:49
 Re: Hydraulic pump droven off fanshaft? in reply to ebbsspeed, 06-27-2005 08:14:18
My father-inlaw had a 47 B with live hydraulics. It came with the loader and they ran the pump with a belt off the flywheel. I guess it depending on how much flow and pressure you need.
Mike M
06-27-2005 10:29:43
I have seen it done many times before to power add on power steering units. Some even look good if mounted up under with care. JD even done this on the later model tractors so it must be doable without harming too much.You could also add a pump unit between the gov. case and the mag.
