730 pto stays on and trans fluid in pto.
JDJACK
06-27-2005 07:58:54
Going to be working on 730D that pto will still turn some with pto disengaged. Had tried to adjust before but something inside is wrong. Also noticed that there is transmission fluid in pto housing. Is there a seal for keeping fluid from leaking in the pto housing? Any advice would be great. Need to get working for baling hay soon.
Sharpie
06-27-2005 20:17:58
 Re: 730 pto stays on and trans fluid in pto. in reply to JDJACK, 06-27-2005 07:58:54
It sounds like it needs a new brake, mine was doing that and I adjusted it as far as I could, but couldn't get it to stop turning. I instaled a new pto brake and now it works perfect. I also am running straight 10 weight oil now too. How do you know that trans oil is getting in?
Sharpie
06-27-2005 20:15:09
mike brown
06-27-2005 13:33:15
Hi Jack;
Yes there is a seal and it is inside the tractor betweeen the trans caseand the housing on the back of the tractor. That back housing will have to come off to get to the seal. I had mine done since I didn't have the heavy duty shop hoist needed to remove it. I believe it isn't that difficult if you have the lifting equipment. It's a commonly needed repair. I'd say all these vintage tractors either have had it done or need it.
The heavy oil in the pto is causing the shaft to turn when disengaged. A bit like a torque converter.
CFWelles
07-01-2005 15:36:48
 Re: 730 pto stays on and trans fluid in pto. in reply to mike brown, 06-27-2005 13:33:15
I'd like to chime in on Mike Brown's comment on the heavy oil. I just finished a complete rebuild for the first time on this same tractor. I'd guess that the rockshaft housing weighs 500 lbs. I have a real good backhoe with loader cylinders that hold really well. If you have something that lifts this kind of weight other than the ideal...a jib or bridge crane...you can do this. I bet you find the brake plate friction material worn off or close to it. Especially if you have been trying to stop it with the heavy oil getting in there. The new seals from Deere for the clutch pump shaft which are leaking and allowing the transmission oil to leak in go in back to back to replace the oiiginal seal that contained two reversed sealing lips and is no longer available. Make sure you inspect the steel backed bronze bushing closely that guides the tip of the clutch shaft where it joins the transmission output shaft that comes through the clutch gear pump. This job is doable if you are a good mechanic, but is challenging. I had a lot of trouble reinstalling the clutch pack into the fingered cup until I adjusted the clutch pack to be locked up while inserting. This was the biggest hassle. Read the comments of some more experienced posters than I concerning my discussion and questions of the repair. Search "730 Powershaft". Also, all my parts from Deere plus some new timken bearings from my local bearing house for the pto output shaft cost about $500.00. I replaced all thirteen friction faced clutch disks and three driven discs that were heat scored. You also get to have a good look into your transmission and get to clean out the bottom with this repair.
