Rear axles on model B
Ken Tabor
06-26-2005 19:27:46
I have a 46 B. Am trying to get the axels in the housing with the new bearings etc. The bull gears are in place as are all the bearings etc. I can't get the large nut to pull everything tight. The nut at the bull gears is as tight as I can get it and it is only half on the axel shafts. I know the bearing cones and cups are on right. I put the felt retainers on as drawn in the parts manual. Could it be that the inner bearing is not going on the shaft Suggestions would be appreciated.
Jason Z in MO
06-27-2005 13:17:27
 Re: Rear axles on model B in reply to Ken Tabor, 06-26-2005 19:27:46
is there any end play on the axles? Does the axle rotate smoothly?
Ken Tabor
06-28-2005 12:37:09
 Re: Rear axles on model B in reply to Jason Z in MO, 06-27-2005 13:17:27
No end play that I can feel but the axel spins smoothly Nut on only half way at the bull gears. I am wondering if the inner roller bearing is not going on the shaft all the way and that is the problem or if somehow I misinstalled something
Jason Z in MO
06-29-2005 08:34:23
 Re: Rear axles on model B in reply to Ken Tabor, 06-28-2005 12:37:09
Ken,
Maybe the outer bearing and felt seal retainer stuff isn't seated all the way out on the shoulder of the axle?
