730 Lp clutch acting UP, anybody,Give me a hint
Ben.So.Tex
06-26-2005 18:59:22
Sometimes when I want to engage the clutch it dosen't want to go in, I can hold the handle and it will go forward but will not snap. I can wiggle it back and forth and then it will engage. It started this about a month ago. What could be wore to cause this? (NOTE The clutch needs to be ajusted, it has a weak snap and I will ajust that next week and see if that might be the problem} Never had this happen on any of my other JD's Thanks Ben
Sharpie
06-26-2005 20:11:46
 Re: 730 Lp clutch acting UP, anybody,Give me a hin in reply to Ben.So.Tex, 06-26-2005 18:59:22
I just had the same problem on my 830. If you can't adjust the clutch enough it will need new clutch dogs. They have a socket hole in them that gets wore to deep by the "toggles". They are a lot of momey so I filled the bottom of the holes with weld and used a 3/4" carbide ball nose end mill to re cut the socket holes to the proper depth. My clutch works prefect now. If you dont have the tools to rebuild the dogs just buy new ones. Good Luck
