2030 hyd.
J3
06-26-2005 18:55:36
I have a 2030 that is having hyd. problems. It acts like it is not getting sufficient oil flow. If you try to turn real fast it is hard to turn. The arms take forever to come up and jerk when doing so. The same is true for the remotes. Most of the time if you turn the wheel real slow it steers OK or if you rev it up it does OK on the steering but the lifts never work quickly or without jerking. I have changed the hyd. filter and checked the fluid level. Also changed the valves in the steering housing. Any ideas?
msb
06-26-2005 19:04:14
 Re: 2030 hyd. in reply to J3, 06-26-2005 18:55:36
Checked the suction screen in the bottom of the transmission?Could be plugged.
