gillfill6 -- Welcome to one of those trial & see jobs as relates to the "H" tractor. We are dealing with an eccentric bearing housing (H707R) that contains the left camshaft bearing. The idea is that by rotating the bearing housing a quarter of a turn at a time, the camshaft is moved closer to, or further from the cranshaft. For the sake of discussion, think of UP as NORTH and LEFT as WEST. The cam shaft gear is NORTHEAST of the crankshaft gear. Note that the governor gear is directly NORTH of the cam shaft gear. Therefore any movement of the cam shaft's center will affect one relationship differently than the other. It is the relationship between the crankshaft gear and cam shaft gear that is being adjusted. There is no adjustment to be made between governor gear & the cam shaft gear. Next, observe that of the four corners of H707R, one is not rounded -- this square corner cannot be oriented toward the crankshaft b/c of interference with the left main bearing housing. Thus, there are but three locations this housing can be in. Now for the good part. Pick a setting, install the bearing, tighten the big nut and at least two of the 3/8 nuts securing the H707R - then test for backlash. Measure by how much of a tooth on the cam gear goes past a certain point of the main case; recording this value in accordance with where the squared corner of H707R is! Then loosen the big nut and the two 3/8 nuts, withdraw the bearing housing so as to make another 1/4-turn rotation, install the bearing, tighten the big nut & 3/8 nuts and then test for backlash as before! Repeat until you achieve the setting desired. The criteria is to adjust for minimum backlash -- but you must have some! Be Blessed.
