JD 3020 pto problem
farmerherron
06-26-2005 13:04:33
I have a 3020D synchro with side console. I was driving home in 8th gear wide open when the pto suddenly engaged. The lever never moved on dash and feels like it still moves linkages. Whenever the tractor's foot clutch is engaged the pto runs even though the lever on dash is in the full off position. Any help would be appreciated.
Thanks
buickanddeere
06-26-2005 15:03:03
 Is there a pattern here, same guy with two busted in reply to farmerherron, 06-26-2005 13:04:33
Is there a pattern here, same guy with two busted pto's .A 3020 and a 4020 at the same time? I would say clutch fingers/springs and maybe bearing problems.
Bob
06-26-2005 13:14:51
 Re: JD 3020 pto problem in reply to farmerherron, 06-26-2005 13:04:33
Probablt a broken bolt or other problem in the pressure plate, which is a combination unit for both the foot clutch and the PTO clutch.
