JD 4020 pto problem
farmerherron
06-26-2005 13:00:08
I have a 4020D synchro without side console. When pto is engaged a loud chatter or knocking begins coming from housing below pto lever. Pto stills rotates but something is not right I fear. Problem started suddenly as I raked one hay field with normal function and then moved to another field and the sound appeared. Any ideas of what the problem is and steps to fix would be appreciated.
Thanks
ET
06-27-2005 09:11:51
 Re: JD 4020 pto problem in reply to farmerherron, 06-26-2005 13:00:08
Take the cover off the bottom of the clutch housing and look up in there. I think the pto throw in bearing is gone. Did you ever give that grease fitting behind the clutch pedal a shot or two of grease? You can look at the clutch in your 3020 the same way.
Bob
06-26-2005 13:13:12
Get it checked out before running it any more! As the other poster said, it could be a bad gear, but I have seen two instances over the years where a finger came off of the pressure plate and grenaded through the clutch housing. That would probably require a change of shorts, so verify that things are OK there before proceeding!
twopop
06-26-2005 13:07:24
probably a broken tooth on the pto gear.
