4010 remote hydraulics
D. meyer
06-26-2005 10:21:47
We have a 4010 at our church camp, it has a loader that uses the remote hydraulics on the back of the tractor for operation. We are unable to operate the bucket (nothing happens when you operate the lever) and the loader won't stay in one position, it constantly will lose height. As usual, a lot of will, but not much $.
Thank you for any Ideas.
Dave M.
msb
06-26-2005 17:10:08
 Re: 4010 remote hydraulics in reply to D. meyer, 06-26-2005 10:21:47
Try switching the two sets of hoses to see if the problem is transfered to the other function.If it is then the problem is in the valve under the hood.If the problem stays with the bucket function then the problem is in one of the bucket cylinders(unless it has only one cylinder).
twopop
06-26-2005 13:04:55
the first thing to check,would be the cylinders of the loader.thr seals may be leaking by.had a bucket cylinder,last week that the nut inside the cylinder came off the shaft and the bucket wouldnt move.
