4020 fuel lines leak
Tom/Idaho
06-26-2005 10:15:37
4020 with re-built Bendix injectors leak on the pressure and return hook up connectors. I used the new washers that came from JD with the head gasket kit and tried the new ones the injector rebuild guy gave me. Both leak, especially on #1 and #2. I tried the old ones that appear to be made of copper and they don't help. Tractor sat for a long, long time, but runs very good (after the rebuild, of course). Return line to tank is clear and all hook up flat spots are smooth. Does anyone have an idea as to what I am missing as I don't think this should be this difficult. Thanks, Tom/Idaho
3010 Ken
06-30-2005 04:52:48
 Re: 4020 fuel lines leak in reply to Tom/Idaho, 06-26-2005 10:15:37
Morning Tom; Just saw your post this am.Had the same problem w/my 3010 last year.I found that dressing the banjo fittings was the ticket.And like msb says you have to clean the bolts and related.Msb,I'm going to try the paint thinner trick next time instead of starting fluid,thanks for the tip! Kenny
scdietsche
06-26-2005 20:11:05
We had the same problem on a 4010 we tried putting new washers in and finally got a new fuel line and that fixed the problem
ron blan
06-26-2005 18:20:52
try doubling the washers. i fought this problem on a 4010 after an engine rebuild. it worked for me.
msb
06-26-2005 17:49:21
Two things: If you look closely at those washers(copper or steel),you will see they are sort of convex where they were stamped out on a punch press.Place the washers with the cupped side towards the injector.But before you do that,wash the injector bolt holes, washers,banjo fittings and the piano bolts with a quick evaporation paint thinner.I have used John Deere paint thinner for this for over 40 years with no problem so don't let anyone talk you out of it.Blow the parts completely dry with compressed air.This removes any film of fuel that attracts microscopic dust and dirt.You may think you are working in a clean enviornment,but just dip a piece of glass in some diesel fuel, hold it up in the air and watch specks of dirt attach to the fuel on the glass.Finally, be sure the lines are not moved when tightening the bolts.Any small misalignment will cause the lines to actually loosen the bolts from engine vibration.Also be sure to replace any missing line clamps.They also serve to arrest the vibration that cause the lines to start leaking.
Tom/Idaho
06-26-2005 14:18:28
What is really tight? I am afraid if I go a 'hair' tighter I will break something. Is there a torque for the connecting bolts? I have several manuals and I can't find anything on tightening the fuel lines. The rings or gaskets are made of steel or at least a magnet will pick them up.
The tractor sat for a long time but everything was hooked up. I took off the fuel lines and dressed up the flat mating parts, but it did'nt help.
Could the pump be putting out too much pressure?
Thanks again, Tom/Idaho
Hayfarmer
06-26-2005 11:01:31
I used to work on a lot of these tractors. Believe the washer is steel or it looks that way. The line has to be really tight. If the steel lines still leak with new washers and new injectors I would think the only thing left would be that the surface on the line connection is bad, maybepitted if it sat for some time.
