Fuel shut off valve for a 720D cranking engine.
Dirtjockey
06-26-2005 08:24:33
Does anyone have an idea were you can buy a cranking engine fuel shut of valve? John Deere says they have them but when you get it is totally different and won't work. Looks like a common valve with the cross handle removed. The trouble is the valve is much bigger than they are made today, both in length and Shaft size.
buickanddeere
06-26-2005 17:42:28
 Re: Fuel shut off valve for a 720D cranking engine in reply to Dirtjockey, 06-26-2005 08:24:33
I've never tried but it a job waiting to do. Rumour has it standard "O" rings can be jammed in there to make the original valve seal up?
JonM
06-26-2005 15:44:20
I had the same problem, I went to local farm store and found a shutoff similar to the deere part, but it had a small pin through the shaft instead of the riveted part you mentioned, I made a new universal joint for the smaller diameter of the shutoff shaft, drilled round stock and welded some cutoff chain links to make it similar to the original. hope this helps
JonM
Dan in Ohio
06-26-2005 10:03:32
Are you talking about a manual shut off valve or the oil pressure operated one. I would like to put the original manual valve back on my 70 D std. I thought the valve is still abvailable from JD but I have'nt actually seen a new one. I will be interested in what you find out. I took off the oil pressure valve and put a valve on at the gas tank(could not make that oil pressure valve work).
Dirtjockey
06-26-2005 10:23:36
 Re: Fuel shut off valve for a 720D cranking engine in reply to Dan in Ohio, 06-26-2005 10:03:32
yes, it is the manual shut off valve. Brass with a tee configuration. My tractor has been modifed to remove the auto shut off. The original valve that I have found out and have been told is a commercial brass tee shut off valve modified by removing the handle out of the "T" shut off shaft. John Deere then extended the operating mechanism by adding a universal joint secured with set screw and a long handle with lever to operate it remotely so to speak. The new one you get from JD now is much shorter has a riveted hollow shaft with a pressed steel handle not a pressed thru shaft handle. Even if you could take the handle off it is too short to use. I take some one a JD thought a shut off valve's a shut off valve. They got it wrong this time
Spoker
06-26-2005 10:14:14
Dan did you change the diaphrams in the oil and fuel pump next to the pressure switch? You might have had to adjust the movement of the diaphrams with the adjustment screw which limits the movement of the diaphram. Deere has the diaphrams and they come 5 to a package. You only need 2, of course you already knew that. Just my two cents worth.
Dan in Ohio
06-28-2005 08:11:06
 Re: Fuel shut off valve for a 720D cranking engine in reply to Spoker, 06-26-2005 10:14:14
Spoker, yes I did get new diaphrams from deere and it still would not work so I just put on a sediment bowl with shut off valve instead. May not be original equipment but I have seen other 70 D with this same set up. Sediment bowl is the same as on my 110 garden tractor.
