404 Diesel starting noises
txgrn
06-26-2005 05:40:34
Is the 404 supposed to make rumbling noises in the first 2-3 seconds immediately after starting, before the oil pressure pops up?
Mine has 4000 hrs, has been well cared for, runs like a top, and uses no oil.
But I just noticed yesterday, before the gaps between the bearings and the things they are bearing on fill up with oil, there is a definite rumble. Can't be good.
Didn't notice it before but now that I have 2 ea. 950 cca 12v batteries wired in parallel, 00 cables, and a 3" straight pipe output, it starts really fast. Guess before when it would grind and grind it gave the mains time to fill with oil before it lit off.
Now you don't suppose the design engineer figured that out and deliberately made it a sluggish starter, now do you? Naw, I don't.
Maybe I'll just leave the fuel kill knob pulled out for a few seconds while cranking to give it time to get some lube.
Mark
msb
06-26-2005 18:21:38
 Re: 404 Diesel starting noises in reply to txgrn, 06-26-2005 05:40:34
Naw? You are correct.Deere engineers were quite proud of the fact that the engine they designed had one of the shortest oil pump pickups on the market.It was included in one of their sales meeting pitches when comparing the 4320? to the corresponding IHC (1256? I can't remember) tractors of the time.Your concern is not something I would worry about.Probably a change of engine sound dynamics due to the shorter cranking duration.There should be more than adequate residual oil on the rod and main bearings to give plenty of lubrication for that short period of time.Cranking the engine before opening the throttle sounds like a good idea though.Would be an even better idea on a turbocharged engine.
