49 MDL A PTO Seal / Tranny Leak
Lee
02-26-2004 10:55:49
Gentlemen -- At the end of the season last fall I bumped my bush hog and oil started leaking out steadily from around the PTO shaft on my Powr Trol. A bunch came out. I am hoping that my guess is right that I probably damaged the PTO seal and maybe the tranny oil came out... Does this sound reasonable and if so how bad of a job is it to replace the seal. Thanks much in advance. Deciding if I am brave enought to tackle it myself.
Jim
02-27-2004 16:16:45
 Re: 49 MDL A PTO Seal / Tranny Leak in reply to Lee, 02-26-2004 10:55:49
Lee---- I have a 47A---I had to take my pump apart this winter---due to the pto shaft moving in and out to far----there is a C clip inside the cover that may have come out of its grove---if tha pto shaft moves in and out more that 1/8 inch..the clip problebly came out of the grove.this may cause the seal to ride in a differnet spot on the shaft,causing a leak... Good luck..
Jack
02-27-2004 06:36:26
The oil coming out is hydraulic oil, as the seal on the powershaft is actually for hydraulic oil control. Transmission oil (gear lube) is retained in the differential area via a slip-fit collar & spring-loaded accumultor seal.
The seal in question can be had from Deere (usually a good idea to 2x the seal) and can be installed with ease.
Lee
02-27-2004 10:02:52
 Re: Re: 49 MDL A PTO Seal / Tranny Leak in reply to Jack, 02-27-2004 06:36:26
THANKS! Sounds like great news!!! I really appreciate it and will tackle it tomorrow!
Lee
Dave K
02-26-2004 11:46:20
Not sure what the relation is of the pwr trol to the pwr take off. The PTO runs the pump for the pwr trol but the pwr trol oil is not the transmission oil. I have had my pwr trol all apart and rebuilt it but did not have to touch the PTO. There is a bearing and seal on the PTO shaft but I have not had that apart on mine. Mine is a 1948 so may be a little different. Lots of folks on here with a lot more know-how about this so I am sure you will get some help.In general, these are not difficult to work on.
Dave
Lee
02-26-2004 12:06:56
 Re: Re: 49 MDL A PTO Seal / Tranny Leak in reply to Dave K, 02-26-2004 11:46:20
Thanks for the response. You are right I think in that my issue may just be that the PTO seal came loose and maybe what drained out was transmission oil.
Dave K
02-27-2004 08:36:58
 Re: Re: Re: 49 MDL A PTO Seal / Tranny Leak in reply to Lee, 02-26-2004 12:06:56
That should be hydraulic oil that leaked out, not trannismission oil. Tranny oil is a lot heavier and smells a lot different from the hyd oil. Did you check the fluid level in your pwrtrol to see if it leaked down?
Dave
Lee
02-27-2004 10:01:47
 Re: Re: Re: Re: 49 MDL A PTO Seal / Tranny Leak in reply to Dave K, 02-27-2004 08:36:58
I didn't but I will. I am still trying to find out where to check/add tranny oil on the tractor. It was my grandfathers and I have used it for years but am now having to get real familiar with it. Thanks!
Lee
Jack
02-27-2004 10:37:04
 Re: Re: Re: Re: Re: 49 MDL A PTO Seal / Tranny Lea in reply to Lee, 02-27-2004 10:01:47
To check / add transmission oil (gear lube), there should be a pipe plug on the RH side of the rear cover, slightly below the centerline of your rear axle. The plug will have an angled boss (30 deg?) and oil can be added/checked. These tractors really like GL-1 140W (Straight 140W), as the axle seals have tendency to leak after 55+ years. It probably wouldn't hurt to change it. Don't be afraid to run it a little low, as the adhesion properties will help wick it up into the transmission gears for proper lubrication.
The Powr-Trol (hyd) has cap on top of housing, also mounted at an angle. Usually, 20W Non-Detergent is standard, although, given your project (you will end up flushing all fluid out when changing the seal) you can substitute modern Hydraulic fluid instead of motor oil. Make certain you only use non-detergent motor oil, as you do not want your fluid to foam. It's a good idea to order an operator's manual and parts manual, both are available directly from Deere.
