Loren, in addition to Maarks good advice, heres a few more things to look at. Points are indeed a leading cause of a non sparking mag, if only gray oxide coated a non abrasive clean/buff/polish may make them work, but if they were burned or pitted or carboned up, I would try a fresh set of points and condensor n see what happens. ARE THE POINTS GAPPED CORRECT????? ???? CHECK THAT Next even if all else is good, at cranking speeds a mag will never fire UNLESS THE SPRING WIND N TRIP MECHANISH ALL WORKS. Does the mag produce a sharp loud distinctive SNAP when you are cranking the engine over????? ???? If not, she wont fire. HOWEVER, if the spring wind n trip is faulty she could still pull start n run fine. Try a pull start????? ????? Sometimes on those mags that external kill switch terminal stud pass through insulation goes bad and that kills the spark. Try to remove any wire from the points to that kill stud (if it has one) n see what happens ????? ???? Nowwwww w if the points are good and gapped and the condensors is good and she SNAPS loud n sharp and no wires to the points or to the kill stud or the studs insulation is bad but still no spark,,,,, ,, the coil may be bad or there could be simple cap or rotor or coil pickup problems. WHAT MAKE N MODEL MAG IS IT (Wico X?) ????? ?? DOES IT SNAPPPPP PPP???? Let me know those things and check for a shorted kill switch stud or wire and I will go into more detailed troubleshooting tips. No use until I know what you have. There could be a coil springy thingy contactor problem on those Wicos?? How are you checking for a spark?? With plugs or just plug wires??? Cuz maybe the plugs are bad???? A plug wire into a tower and its other bare end to within 1/8 inch away from the mags metal side ought to fire when she snaps (not every snap, depends on what mag) Lemme know, post back your results and more questions and if necessary I will go into more detailed coil n cap n rotor n coil contactor problems. PS You said a Mag, they used some Wico XB Battery Powered distributors, you sure you have a mag or is it a distributor???? I guess its a mag cuz it sounds like that terminal on your unit isnt being used but if it were a Wico XB distributor, they gotta have voltage on an external terminal to work !!!!! !!Thats NOT a kill switch on those, its a voltage input John T Nordhoff
