4020 questions for GeraldJ
Nylon
06-25-2005 11:46:21
I tried to send e mail to [email protected] but I keep getting it returned so I will post the text here any help would be great.
Gerald. I have read alot of your posts I have gone to your web site to fabricate this check valeve but I can't make out your writing. Any chance you could e mail me a text typed version of those instructions? I just bought a 68 4020 w 148 loader. I am very used to a IH 460. We used to have a 4020 (Field) and an M (loader tractor) and a 8n (elevator rake and trailors) That was 30 years ago. I am relearning all over and it is more for some mowing and dirt work and woods work. This 68 I know very little about. It seems to be pretty strong...shifts well. Is a synchro. Is a 12 volt with alternator....2 batteries in tipoutboxes under the cab. I live in northern minnesota. Iam worried about the cold weather start. And finding outhow bad the motor is. Are there any diagnostics that are relatively simple that can indicate engine condition. Diesel is new territory for me. Also what would be your checklist of tuneups that would avert later disasters? I want to put loader controls close to my right hand and take them off the dash / rear dual remotes. What type of valve will I need? I don't seem to have down pressure on my loader arms. I have down pressure on the bucket but the loader wont hold down. Is there an adjustment? ie float or do Ihavea problem? Sorry for all the questions but you seem to know what is what. John
Heat Houser
06-26-2005 09:44:31
 Re: 4020 questions for GeraldJ in reply to Nylon, 06-25-2005 11:46:21
On my 4010 which is the same as your 4020, I have purchased a Prince Hydraulics>Link
Valve>Link number RD522GCGA5A4B1....3/4 NPT inlet/outlet...1/2 NPT work ports.Valve info:Two spools with float on spool number 1. 4 way spools (means they are double acting, raise and down pressure) The spools are hydraulically in tandem, not series. The valve has load checks.
You will need the closed center plug, part # 660312005. I purchased the 45 deg. bent joy stick kit, p/n 660150012. The straight is p/n 660150011 if this would be better in your application.
Nylon
06-26-2005 10:39:40
 Re: 4020 questions for GeraldJ in reply to Heat Houser, 06-26-2005 09:44:31
Heat houser,
Nothing beats a cut and paste link. How did you ever figure out which set up was correct out of all those options? Can the float option be bypassed? I would want to have down pressure on both the bucket and the loader. Also would want both lines to operate at same time. as in dump bucket while lifting or lowering and all combinations thereof.
And of course the big question is....how much $ approximately?
Thanks Much,
John
Heat Houser
06-30-2005 21:10:40
 Re: 4020 questions for GeraldJ in reply to Nylon, 06-26-2005 10:39:40
Spools in tandem means that both spools always share what ever oil is being supplied. Both functions will work at the same time but you will have to meter the flow between the two spools by manipulating the lever.
The float option means the spool has 4 positions, raise, hold (center) lower, and (yanked all one way into the detent), float. On my loader, I seldom yank it into float unless I am back dragging some dirt etc. I usually use down pressure (and of course raise and bucket curl and dump) I purchased mine from Force America. I don't remember the price but I think around $275 or so.
I plumbed inlet and outlet into the ports on the tractor. many people drill and tap a hole in the filter cover for return oil but I think it looks a little Rube Goldberg.
Heat Houser
06-30-2005 21:18:28
 Re: 4020 questions for GeraldJ in reply to Heat Houser, 06-30-2005 21:10:40
Forgot that this valve has a relief. This will have to be adjusted up above the system pressure, turn it in 1 1/2 to 2 turns. The pump quits pumping on the Deere's to limit the pressure so the relief is not required. You need to adjust it up so it cannot ever open.
If you want, I can take some photos of my installation. I will need an e-mail address.
Nylon
07-01-2005 21:36:32
 Heathouser in reply to Heat Houser, 06-30-2005 21:18:28
Heathouser,
Would like pics of your setup.
thanks,
John
buickanddeere
06-25-2005 13:12:25
 sorry Gerald for jumping in Re: 4020 questions for in reply to Nylon, 06-25-2005 11:46:21
Where and what valves are you using now? Where are the hydraulics tied into the tractor? Do the hydraulics work fine until about 10 seconds after the clutch pedal is pushed? Do you have access to the dynometer? That really shows what a tractor's true condition is. A PROPERLY done 12V conversion works ok. A good 24V will outcrank it however. Is there a coolant and oil pan heater installed and working?
Nylon
06-25-2005 13:54:58
 Re: sorry Gerald for jumping in Re: 4020 questions in reply to buickanddeere , 06-25-2005 13:12:25
Thanks for jumping in. I take any help I can get. The loader is set up on dual remotes in back. The controls are on the dash/instru panel...the 3 point is furthest to right and the loader functions are on the 2 left levers. I did some loader work with it and clutch had no problem but yesterday it shuddered going up a bit with clutch in. I had read these posts already and let out the cluth and I was ok but I will need to raise and lower with clutch in. This tractor was a loader tractor for many many years at a cannery in southern MN probably green giant peas and or corn. It probably idled a lot especially in cold Minnesota winters. But the loader had to be used with the clutch for its entire life so I am not sure about this. I have ordered manuals because right now I cant even tell where the hydro pump is. It has a cab too which makes getting at things a bit tricky. I was told that it had a rebuild 2000 hours ago but what was redone is unknown. I can tell that it has been split as the bolt heads show signs. Total hours are 9722. I believe alot of those hours were at idle. It was never a field pull tractor.
I would like to add a set of loader controls to my right at comfort distance from seat and arm rest. This would free up the rear remotes too.
Right now I have down pressure on the bucket but not on the loader arms. is there a float function or something I can adjust? I need down pressure on both the bucket and the loader. It would be nice to have one rear remote with down pressure and one with float which seems to be the way it currently is unless it is some type of failure. Any tips on this would be nice.
The bucket doesn't bleed down but the loader does if left up when tractor is shut off. If loader is left about waist hi at shut off it will be on the ground in about and hour and 15 min. The 3 point did drop at first but is now holding up at shut off and several days later.
The loader pins are toast too. it is a jd 148. Can you get replacement bushings or something to make the loader nice and tight?
Where I am at up here in MN is woods, hay & cattle grazing as we don't have the degree days for cropping.
Tx Jim
06-26-2005 03:49:30
 Re: sorry Gerald for jumping in Re: 4020 questions in reply to Nylon, 06-25-2005 13:54:58
Nylon,be sure and get a closed center hyd.valve.I know Gerald talks about adding a restrictor valve but I never did on loader installations and never had any problems.I guess it's each to their own ideas.It's important as previosly stated to return oil to filter cover!! Tx Jim
Pete/ME
06-26-2005 03:27:11
Think your best bet would be to get a salvaged loader valve, either the old two handle one or the newer four-way joystick. By-pass the SCV's, "T" off from the line in front of the brake pedal and dump directly into the filter sump (You'll need a cover with a fitting.). Don't know if you'll need a flow control valve, others could help you there.
