720 Gas tank question.
Bill Tremel
06-25-2005 05:51:43
Thanks so much for my earlier post. While I'm on the topic of my 720G, I have another question. This is more of an nuicence issue. The tractor has it's fuel outlet toward the front of the gas tank. So, when you clime a hill with a half tank of fuel, you run out of gas. For this reason, I always keep a full tank of fuel in the tractor. If I don't, air will accumulate in the fuel filter and the engine will starve for fuel.
Why is my fuel outlet toward the front instead of the rear? Can I drill and tap the rear of the tank and move my fuel outlet? This seems like a crazy set up if you ask me.
Gerry_Luzerne_MI
06-26-2005 17:23:21
 Re: 720 Gas tank question. in reply to Bill Tremel, 06-25-2005 05:51:43
Kevin: I have a 720 gas and the gas shut off is in the rear. Not sure how you got yours.... Gerry..
Kevin L.
06-25-2005 20:17:42
not sure if you can change the angle by the straps holding the tank in place with extra rubber on top but wonder as much above the angle of the tractor going up the hill.
not sure about the thickness if you can get away with just drilling and tapping a new hole without brazing or welding a new fitting to the tank and that's a dangerous task.
