2950 PTO very weak??
Balawender Farm
06-24-2005 19:48:57
tlb337
06-29-2005 18:46:28
 Re: 2950 PTO very weak?? in reply to Balawender Farm, 06-24-2005 19:48:57
does the lever go into detent if so then you are angaging the valve does it shange the condition if you are in hi or low range if it does then what you have is a high pressure leak in the trans probably one of the suppply tubes you can take off the center floor plate and on the pto valve housing there is a test port you can check for pressure you. drain the hyd. fluid and check the sump screen for clutch disk debris if there is none the it is more likely that you have a pressure leak pull the valve from the top os the trans and there will be 4 small tubes going into the trans and 2 metal pipes one is supply oil from the trans pump and the other is return from the valve. of the four little tubes 1 is for lube pressure 1 is for pto engagement and 2 are for the two speed. you can pressurize these with a rubber tipped air blower ind listen in the case for excessive bypassing if you get alot around the shaft then the sealing rings or piston rings are leaking you can also use a small screwdriver and look into the clutch drumm and inspect the disks for wear if anything internal you will have to pull the cab and split. hope some of this helps.
