3-way valve repair
Ghostrider
06-24-2005 18:33:22
Here are the images of the 3way valve repair. The second is the fuel shutoff valve repair for the original sediment bowl. The o-rings are standard Buna N rubber sizes. Hope this helps people out!
Link
http://www.rieckesbaysidegallery.com/programfiles/talers/ACF2FE9.jpg
jdjoe_97
06-28-2005 19:31:04
 Re: 3-way valve repair in reply to Ghostrider, 06-24-2005 18:33:22
I was unable to view links, what"s the trick. Joe
Pat Browning
06-25-2005 18:16:00
Ghostrider -- I read the note on O-Rings to say that "-015" and "-016" O-Rings are used for seals, - - -
The note then goes on to say "-208" for tension.
Am I reading this right -- that three O-Rings are used; the two smaller ones on the cuts made in the tapered cylinder and a larger one (the -208) in place of the D2122R packing?
Glen in TX
06-25-2005 08:12:42
Thanks Ghostrider! I'll try this sometime.
