Front wheel hubs and caps color
Dave in SV
06-24-2005 15:41:32
I need to replace (at least one) front wheel on my '49 A. I realize that the wheel itself should be painted yellow. The pedestal and spindle extension is green. What about the hub and cap? Presently, the hubs and caps are green, which looks a bit strange protruding through yellow wheels.
F-I-T
06-25-2005 14:21:37
 Re: Front wheel hubs and caps color in reply to Dave in SV, 06-24-2005 15:41:32
Dave:
When Deere painted your tractor in the factory, it had steel wheels front and rear just for transport. They moved the wheels from chassis to chassis and when they were stringy with green globs of overspray, they would send the wheels over to the wheelabrator and blast department to have them cleaned.
The rear and front wheels and tires were assembled elsewhere and were installed after the chassis was painted green. The hub was already mounted and bolted in the rim with the bearing cap attached and everything was painted yellow. Then the tires were installed. In final assembly they would remove the just the front hub bearing cap and slide the wheel assembly on the spindle and set the bearings. Then they would attach the cap using a new gasket and the assembly was complete.
And that's how the front wheels came from the factory.
Frank
Pat Browning
06-25-2005 17:05:34
 Re: Front wheel hubs and caps color in reply to F-I-T, 06-25-2005 14:21:37
Knowing the factory flow is almost key to painting a tractor. My neighbor (Milton, Florida) once worked at a Ford tractor plant, and when I spruced up a Ford, I always consulted with him before making up my painting plan. Well done Frank
Dave in SV
06-25-2005 16:05:37
So... bottom line is that the hubs and caps should be yellow, right? In my mind, that would look better than the way mine are presently!
Thanks for the thourough and historical explanation, Frank.
55 50
06-24-2005 16:38:42
Some folks paint the hub and cap green. Personally I hate that look. Furthermore it is wrong if you ask the "correct police". But it is yours and you can do as you like with it.
Pat Browning
06-24-2005 17:20:29
 Re: Front wheel hubs and caps color in reply to 55 50, 06-24-2005 16:38:42
I don't think it is so much a mattter of "correct police" as it is a man asking what is the scheme of things. Most of could care less if he wants to paint his tractor pink with white tires because it is his, and besides -- might look kind of cute. Here I think the writer wants to know how that tractor would have looked as it left the factory, and Dave -- yellow is the answer for that one.
55 50
06-24-2005 21:14:46
 Re: Front wheel hubs and caps color in reply to Pat Browning, 06-24-2005 17:20:29
I don't "understand" these forums!! What ever I send is most always taken the wrong way. Guess I won't send anything more.
Pat Browning
06-25-2005 02:19:07
 Re: Front wheel hubs and caps color in reply to 55 50, 06-24-2005 21:14:46
55 50 -- No need to take offense. Input is always sought. Most of those asking a question want a simple answer -- they are seeking, and I too am learning to mellow some. But I must admit the words "Correct Police" are distrubing titles and tend to make those who do have the right data appear as some sort of evil people, or meddlers. And by your comment of being taken the wrong way, I see you weren't saying that at all, but rather, just fell into a pattern of the forum. Hang tough -- someone out there needs you -- if not tonight, soon.
Mike M
06-24-2005 19:20:16
Except if you own a early model M or LA the baby moon hub caps were green. Always an exception with these Deere's.
Dave in SV
06-24-2005 18:56:45
There's the answer I was looking for! Yellow it will become!
