Finding TDC on #1 cyl on a 4020
Stephens
06-24-2005 14:41:23
Getting ready to install an injector pump on a 4020. I am tring to get the old one that is still on the tractor set at TDC on #1 cyl before I pull it off. The TDC mark on the flywheel lines up with the 2 marks inside the injector pump, with every revolution of the flywheel. Just don't know which one is the #1 on the comp. stroke. Thanks for any help.
msb
06-24-2005 19:52:10
 Re: Finding TDC on #1 cyl on a 4020 in reply to Stephens, 06-24-2005 14:41:23
Should only line up on every other revolution.If yours lines op on every revolution just go ahead and pull the pump there is a vee mark on the oil pump drive the injection pump drive shaft tang fits into .Set the flywheel on TDC with the vee mark pointing toward the block.The tang and the tang slot are offset so it isn't too hard to tell which way it goes together.
