730 D TRANSFER PUMP
bruce schepler
06-24-2005 12:32:05
730D/S.E. HI, CAN ANYBODY TELL ME THE REMOVAL PROCEDURE AND WHAT TO LOOK FOR IN THE FUEL TRANSFER PUMP. ARE THEY TOUGH TO REBUILD. MY TRACTOR ISN'T RUNNING RIGHT. I THINK IT IS STARVING FOR FUEL. CHANGE FILTERS,TREATED FUEL WITH SEA FOAM CONDITIONER, HAD INJECTORS CHECKED AND CLEANED,NEW SPRING @ SHIMS IN FUEL RETURN CHECK VALVE, AND SET VALVE ROCKERS TO .22 COLD.IS THERE A SIMPLE WHY TO BUMP UP THE PRESSURE? I CAN GET 32 PSI OUT OF IT. THANKS A BUNCH/BRUCE
buickanddeere
06-25-2005 06:58:16
 Re: 730 D TRANSFER PUMP in reply to bruce schepler, 06-24-2005 12:32:05
1-800-522-7448 for the operators, service an parts manuals cheap from Mother Deere. A picture is worth a thousand words. That transfer pump pressure regulator slides a spring loaded piston in a bored block with several orifices. If the spring pressure is too high the output pressure will actually drop due to internal bypassing. The piston can't rise and close the bypass port. The bore and piston do get worn and suffer leakage after 45+ years. May have to make a custom over sized piston and bore the block a few thou larger. Best to ship the whole thing to Albert at Renaissance Tractor in Washington State. May as well send the injection pumps and injectors too. The components will be shipped back working 100% for a fair price. Costs less than tinkering with several tries for days and have it still not work. BTW, it's better to use lower case type.
