1948 john deere b have to run with choke half on
darren
06-24-2005 11:35:50
my b runs really good with choke half on at idle but at full throttle will run good with choke off i have cleaned the carb and rebuilt the governor any other ideas thank you
jgc
06-24-2005 18:36:37
 Re: 1948 john deere b have to run with choke half in reply to darren, 06-24-2005 11:35:50
Forgot to mention, also the throttle plate has to fit tightly inside the bore and the disk must ride very close to the sidewall where the small idle ports are. A badly worn throttle shaft, throttle shaft bushings, or a badly worn throttle disk can cause all sorts of problems - it's usually a combination of these, all adding up to poor idle performance.
JGC
06-24-2005 18:30:09
I recently did the carb for a friend's B.
I took out every plug and I used the 6" aircraft bits to clean every passage - the carb worked perfect! Deere sells all of those brass plugs. It makes a really nice looking job if you replace the ones that have damaged heads.
It is really important to clean every passage. I had the carb for my D "tanked" in the really strong commercial cleaner. It still had blocked passages when I got it back.
Jon
Joe Howard
06-24-2005 16:01:42
This one sounds like a country cousin of a long and painful bout I had w/ my 50B. I posted a help request a couple months ago about it only firing on the left cylinder bank, could not get the right cylinder to fire despite changing plugs, wires, mag condenser,points, and coil. Also checked compression, valve lash, timing, nothing worked!! Noticed the boot between the oil-bath air filter assembly and the transition piece on the suction side of the carburator had dropped down creating a vacuum leak there, which compromised the vacuum needed to make an updraft carburator work. Slipped it back into place and clamped same down TIGHT and it is a BRAND NEW TRACTOR!!!!! I blame myself for letting it go along as long as it did..... the operative phrase here is "do the simplest things first"!! I've been whipped many times in my 65 years, but never like that.
Joe Howard
06-24-2005 16:15:33
 Re: 1948 john deere b have to run with choke half in reply to Joe Howard, 06-24-2005 16:01:42
Incidently, my symptoms were EXCACTLY the same as yours; eg, the engine would only run with the choke 1/2 engaged. That alone should have told me it was starved for vacuum.
34gpa
06-24-2005 14:16:43
If it runs wide open with out the choke,the float level is all right. You need to clean the passage ways again, usually it is the one at the bottom of the stem that is plugged, but also if it is a 67 carb,there are 4 holes or 2 on a 73 that go into the venturi that also have to be clean.
Pat Browning
06-24-2005 14:02:21
Darren -- if all the passage ways are clean, the final variable that will cause the fault you have is the float setting too low -- not allowing enough fuel into the bowl. Hook up a Float level test kit -- the fuel level should come up to roughly 3/4 inches below the top of the bowl -- static standing test. If you need a kit, touch base with me.
John T
06-24-2005 12:48:12
Darren, I agree big time with Maark. Unless and until you remove all the idle circuit brass drill plugs and clean/bore those idle passages using the long No 40 and 53 aircraft drill bits (available from Roberts, use correct bit in correct hole only) she aint gonna idle correct or without choke even if you clean n boil out the rest of the carb till the cows come home. The brass drill plugs often require the application of heat just till they start to give of that funny lookin blue green color and then use a good proper size sharp screwdriver and they usually come out.
Did you try adjusting the idle neelde richer n see if that helped??? Try easy simple things first.
Other possible causes of a lean idle are vacuum leaks like at the carb to manifold junction or the carbs throtle shaft bushings. Check that out first also.
If she needed choke at load then I would suspect the main center horizontal brass nozzle also needs removed n all its lil holes cleaned out and/or the float was too low or there wasnt sufficient gas entering the bowl (needle or seat or sediment bowl restriction etc)
Let us know
John T
Maark
06-24-2005 11:52:41
Did you remove all the brass plugs and run a wire through the passages or remove the main nozzle and clean it? Something is still plugged if you need to use the choke..
